How to turn on laptop teamviewer?
Hello Experts,
How to turn on laptop teamviewer? There are some cases that we need a teamviewer in order to share your works to your business partners, friends, thesis group mates and more. I hope you can give me an instruction on how to turn on laptop teamviewer.
Thank you.
Best Answer by Diane Burgess
Answered By 20 points N/A #185393
I have just installed a teamviewer the other day and it is an excellent tool in sharing information, controlling other computer, and the like. If you want to use a team viewer, first download the teamviewer. You can download it here:
https://www.teamviewer.com/en/.
After installation, you will be given a code as your username and a password. To access other computer, share your code to them as well as the password. After doing so, user will be connected to the other and is able to control, manage and share information.
Diane
Answered By 5 points N/A #185394
Hello Jeremy Jack,
You want to turn on your laptop teamviewer. It is very much important to share your works with your partners, friends, thesis group mates and more. To know how to turn on please go to the following link and click. There is a tutorial you can download or watch and follow the instruction. www.youtube.com/watch?v=GS6F-ZuRoqs.  If you follow the instruction you may be able to turn on your teamviewer.
Answered By 0 points N/A #185396
First of all download Teamviewer from its website https://www.teamviewer.com/en/. Now Install Teamviewer. Installation is very easy. If you do not want to install or you do not have admin rights just select "Run" during installation. In other options just select defaults. Hence the installation is completed. After installation teamviewer screen appears. Now note down the ID and password in Remote control tab as shown in the image.
On the meeting tab click "Start Instant Meeting". All the task of your main computer is done on which you want to give presentation. Now on all other computers install/run teamviewer on which you want to receive presentation. And in meeting tab put "meeting ID"  you have noted before and click join meeting. After clicking it will require password. So provide password and it is all done.
Answered By 50 points N/A #185397
Hi
There are many cases where we cannot share the credentials to other and need the work to be done. In that cases Teamviewer acts as a great help. To turn on Teamviewer download the latest version of Teamviewer from the website.
Install the Teamviewer on your laptop. Create a shortcut menu on desktop, while installing. After installation open the Teamviewer icon. It asks for Username of your partner to share with. Enter the username and click on Connect to Partner. It asks for a password. Enter the password.
It the screen of your partner appears on your system.
Answered By 0 points N/A #185399
Hello Jeremy Jack,
First you have to download a Team viewer application.
Install it then login.
Give your username and password to your.
Or if it is installed already,Type TEAMVIEWER on your start menu search programs and filter.
Hope this helped you!
