How to stop ping program system tray when window runs?
nevil merlyn 0 points N/APosted on - 03/22/2013
Hi. I am using ping tool to monitor internet activity and status update. But as window starts then ping program system tray runs automatically and it slows PC for some time. How to turn off it and system tray is full of so many icons.
Here’s my solution for programs that start with Windows. Most programs that, when installed, will automatically start with Windows have options to disable itself from starting up with Windows. But there are times you will encounter applications that don’t have options in disabling itself from starting up with the operating system.
But with the help of the nifty CCleaner, you can enable and disable an application from starting up with Windows. First, go to CCleaner Free Download and download the free version. Once installed, start CCleaner then click “Tools” on the left pane and select “Startup” on the next pane. Now, look for your ping tool on the list and click it to select.
Next, click “Disable” to disable it from the startup group. And that’s it. Close CCleaner and restart your computer. Now, you should no longer see your ping tool starting up with Windows. If you want to convert CCleaner to Pro, download the codes and follow the instructions.
In the evolving online gambling landscape, Maryland has emerged as a beacon for enthusiasts seeking premium digital casino experiences.
The state's regulatory framework and technological infrastructure provide a safe and dynamic environment for players to...
All new users from India can count on a generous 1xBet welcome bonus. You can get a 120% bonus of up to INR 33,000. It applies only to the first deposit, with a minimum...
The first impression buyers have when they visit your mobile app greatly influences their retention rates and overall satisfaction. A well-crafted onboarding process quickly communicates the value buyers get by acquiring your products and...
1....
