How to setting registry ati display manager
I am using window 7 Operating system. There is some problems in my registry anti display manager i don,t know how i can manage registry setting of anti display manager if any body know please help me to fix my problem.
Answered By 5 points N/A #159630
Dear Harford Maud,
As you mentioned “ATI” display manager problem comes from” Windows 7” it probably happens due to “Disable” your “ATI” display manager. The solution is given under:
1. Go to “Control Panel” click on “Display”.
2. Now go to “Change Display Settings” there click on “Advanced Settings”.
3. Now click on “Adapter” tab select “ATI” from the list and then click on “Properties”.
4. Click the “Driver” tab there and click on “Enable” to enable your “ATI”.
