How to set msn auto adjust?
Hi guys,
How to set msn auto adjust? I would like to set my msn messenger to auto adjust according to the number of contact lists and space provided of the laptop’s size, so that it will not be a hassle in my part dragging the border as to what position I’m comfortable to.
Expecting some help, thank you.
Best Answer by Ornelas Harris
Answered By 5 points N/A #187788
This feature you are talking about is called docking. Messenger Plus! Live Enhancer has this feature. This can be downloaded free online.
Here is one link to download. http://www.msgplus.net/Downloads/Download-Details/DocumentID/7644/. It perfectly resizes msn window according to the contact lists and space. It can disable window flashing and taskbar button flashing while receiving messages.
Below screenshots will give you more clear idea.
You can select the options according to your requirement.
Answered By 10 points N/A #187789
Hi Danield,
You can use Messenger Plus! Live Enhancer and it is free. It is a plug-in that will allow you to resize the MSN window according to the number of contacts you have. Here is the download link for the installer:
Once you have installed it you can also disable the flashing of windows and taskbar button when you receive messages, hide contact list taskbar buttons, and dock the window.
