How to Safely Quit Aperture Software?
My Aperture app suddenly becomes unresponsive. So what I did is to force quit it through the Quit Menu under the Activity Viewer. Since then, the error below keeps on popping up. How can I get rid of this and safely quit Aperture and restart it again? Clicking on the Ignore button will just close the error once. But it will soon pop up again. Please help.
You have forced Aperture to quit.
Click Report to see more detailed information and send a report to Apple.
Ignore     Report…
Answered By points N/A #118019
It surely looks like there is some bug in the program so it becomes unresponsive. Programs become unresponsive because of several reason for illustration, the app might be waiting for such a task that will never complete or computing any calculation recklessly.
As you have forced to quit the app and the message appeared, just press “Ignore”.
Because of this force quit, it might be required to have a repair process with Aperture. Just do the following:
1. Locate the Aperture library.
2. Hold down “Command + Option” keys and double-click the Aperture library.
3. When the “Aperture Library First Aid” opens, select “Repair Database” >> press “Repair”.
Now start your Aperture again. It should work fine.
Optionally, you can also choose “Rebuild Database” to make Aperture clean and fresh.
