How to Run background Scripts on Mozilla Firefox
Hi all!
I am using Mozilla Firefox 6.0 on Windows XP. I have written some scripts which I want to run when I open a specific page. How can I run my scripts on Mozilla Firefox?
I don't know if it is possible to run background scripts on Mozilla Firefox. Can anyone tell me if it is possible? If yes, then how can I run it?
Best Answer by shawn13
Answered By 0 points N/A #116952
Hi Erange!
Well, to enable the scripts on your Mozilla Firefox, you have to customize the settings of internet security of your browser (Fire fox). To do so, you have to follow these procedures:
  • Go to the Custom Level > Security Settings > Internet Zone > Open the dialog box > Choose the Enable option in the section of Scripting to active scripting.
  • Then go to menu of Tools > Internet Options and choose the tab of Security.
  • Set the internet settings or zone to default level and then go back and simply refresh the page and you will see the activation.
I am also attaching an image for your ease.
Have a good day!
