How to retrieve password for Dell Venue
Hello Guys! I have a Dell Venue Tab 8 Pro. Did not use it for a month as a result, I forgot my password. It is sad that cannot open my Tab right now. Is there a way to retrieve my password? Or is there a third party tool that I can use to open it.
Answered By 70 points N/A #194067
Bringing back your phone to life requires a hard reset. A hard reset is the reset type that brings the device’s condition as it was bought totally new. It will reset all the data of the OS and bring everything back to normal. But you’ll have to lose your installed apps as you can install them later on. Nothing on your SD card will be changed.
1. Press and hold the power button of your phone for minimum 10 seconds. The phone will turn off during the time.
2. Start the phone normally.
Now, all you have to do is getting back your apps installed on your system either from backup or getting them from Google Play Store.
