How to represent a graph in a C++ program logically?
Asked By 260 points N/A Posted on -
Hi there.
I am just beginning to learn some C++ programming. It is quite interesting and flexible. I think it is a good habit to understand algorithms through implementing them in code. I studied some ways to represent graph in the computer. It seems to me that adjacency matrix is most simplest.
I have heard that they take a lot of space. My question is, how do I use adjacency list to reduce this memory consumption? Do I have to allocate the array size dynamically during runtime? How do I do it?
Is there any simpler way to manage adjacency list?
Best Answer by softwaresynthesis
Answered By 0 points N/A #92825
Joe
If you are using C++ , then why bother using an array with memset ()? Just use vectors instead. It's much easier; trust me. Instead of using
int arr [100]; //fixed use
Vector<int> arr; //no initial size
When adding an element to the last. Instead of
For (end=0; end<100; ++end) if (arr [end] =0) Brea;
arr [end] = new value;
Use
arr. push_back (newval); //auto extend the arr and push the novel to the end
To know more about vector go to
http://en.cppreference.com/w/cpp/container/vector
Answered By 260 points N/A #92828
Thanks a lot,
But how do I declare  a two dimensional vector?
vector<vector < int> > vv;
I guess its becoming more complicated.
Answered By 0 points N/A #92829
You don't need a two dimensional vector.  If your number of nodes has a max limit, you can use an array of vectors instead.
vector<int> adjList[mxNod];
And yes, vector of vector will also do the job. But it is not necessary to save space that much.
Answered By 260 points N/A #92830
But how do I populate it?
int latest=0;
 for(int i=0;i<numberOfEdges;++i)
        cin>>n1;
        cin>>n2;
        adjList[n1].[latest++]=n2;    //n2 is adjacent to n1
Its crashing when I run.
Answered By 0 points N/A #92831
That is because the size of the vector located at adjList[n1] is initially 0. So your program wont find it by accessing adjList[n1][pos] at the first time.
That is obvious because it is not yet created. Instead do something like this;
        cin>>n1;
        cin>>n2;
        adjList[n1].push_back(n2);    //n2 is adjacent to n1
Answered By 260 points N/A #92832
Thank you very much. I really appreciate that.
Answered By 0 points N/A #92833
You are most welcome.
