How to remove a computer from a domain
I have worked group business domain. They I am using for the many years. But now I have left that work and joined a new business group that has a separate domain. I try to enter into the other domain, but I was unable to that as my previous domain stoping me to doing that. Now how to remove a computer from a domain.
Answered By 0 points N/A #185448
Please use the below procedure to remove your computer from the domain.
Log into the domain controller using the authorize administration detail. Open the Active directory user and computer tools and then select the computers. Then a list of the computer will be shown. Then you can right click on your computer and delete it from the list. And then your computer will be removed from the domain of that working group. Then you can also add your computer to the other domain and your computer will be added to that domain easily. You can add only one domain from one computer multiple domain joining is not allowed for a single domain.
