How to play monkey island nokia e63?
Asked By 100 points N/A Posted on -
How to play monkey island nokia e63? My friends downloaded this game application in my nokia e63 mobile phone device. I am not an expert on game settings; let me ask you how to turn on the sound setting for the game? Please guide me on the process.
Kathryn Masud.
Best Answer by Wiedemann Alecia
Answered By 10 points N/A #184034
If your game is a java application then you can easily set the sound for the game. After installing the game you need to go through settings and check for sound options. If there is no settings panel then increase the ring volume and you will be able to set the game volume.
Smith Thompson
Answered By 0 points N/A #184036
It's pretty simple and straightforward.
First, you have to activate the internet connection on your device, then download the game. I can give you a link here:
url : http://www.mpbus.net/Nokia-E63-1899/download/wallpapers-397080-4-Monkey_Islan.htm
After downloading, install the downloaded file and play the game.
You can increase or decrease the sound by going to the sound options from the option menu.
Answered By 0 points N/A #184032
Here You want to know about the way to play monkey island in Nokia e63:
At first you have to download the gameNokia E 63 is a run by symbian software.
You can get full version of Monkey Island.
After downloading the Monkey Island in your Nokia E63 you have to install the game on E 63 application.
lets play.
Thanks
