How to perform rv042 and bt infinity setup?
I just had both rv042 and bt infinity hard and softwares but I am in trouble on how to setup the said materials for use. I am looking for someone to be able to help me get through with this rv042 and bt infinity setup. Thank you very much.
Answered By 0 points N/A #152297
Rvo42 routers are normally used to link several computer systems to one cut resource or it can also be used when linking more than one PC within the same system so that they are able to discuss internet from the same resource using Ethernet wire. No special expertise is required when establishing up Rvo42 wireless router, the first thing is to link your Ethernet wire from your hosting server or device ( this will depend with what you plan to do) link it to the (WAN) slot on your wireless router. Take another Ethernet wire from (port1) of your wireless router and link it to your first PC and connect in the energy wire to an energy resource then change it “on”. The next phase is to connect your wireless router, move to your PC and open your internet browser and use this structure to perform this operate (http: // plus your IP address into your browser) then press enter key. Your IP address can be found on your wireless router or on the card usually packed with the wireless router. Do not forget to get in your details, after verifying that all your configurations are correct simply click on save, then link other computer systems and you are ready to use.
