How to perform a Mac capture screen high resolution?
Hello experts,
How to perform a mac capture screen high resolution? And also inform me the hot key to capture a high screen resolution with mac operating system. I just switch with mac operating system and unfamiliar with all the settings and other feature. Thank you.
Best Answer by Emil Onoon
Answered By 0 points N/A #185428
Hi
I will help you to take high resolution screenshot of your Mac's screen. It is very easy. The hot keys are Command + Shift + 3. It will capture the whole screen area. Another hot key is Command + Shift + 4. The first short cut will place the file on your desktop. The second hot key will capture the area you select.
Answered By 0 points N/A #185429
Hello Jeremy,
To capture high resolution screen shots. Just go to Application -> Utility -> Grab.app.
Actually it comes with your Operating system then it makes it free as well. It produces a TIFF image and almost a size of 5mb per picture, the dimensions are 2560×1600 pixels so it's a really a high quality screen capture.
Thanks
