No of visitors who read this post: 182
Type: Question
Author: Belensienna
No votes yet
I have a file stored on my PC which having the extension of pub and I am unable to open it. I need help in this regard to open this file at my PC. Can anybody know which having this extension and through which application I will be open pub for free. I am waiting for the reply.
Comment viewing options
Hi there,
Actually .pub files are Microsoft Publisher files, in order to view them you have to download and install Microsoft Publisher or .pub files Viewer, You can download the viewer free from this link “http://www.microsoft.com/office/previous/xp/columns/column16.asp “.
Also there is online conversion website for conversion of .pub files to .doc files, after doc conversion you can view it easily even in notepad. Link to online conversion website is “http://www.zamzar.com/ “
You can also convert files of .pub format into pdf format; link to this online conversion is “http://www.conv2pdf.com/ “,
To convert a file to PDF, follow these steps:
Click "Browse", select the file you wish to convert
Click "Convert"
You will be given the choice between downloading the PDF file to your computer or sending it by email
Hope that helps!!
