Hello! Lately I have noticed that there are a lot of files in my computer that I don't use very often but which are still very important to me. I wanted to enhance their security so I was thinking of encryption. Will it help? Which software should I use? People usually say that if you don't know much about encryption its better not to use it, so should I do it? Does encryption compress a file as well?
Encrypting file through compressing them and creating password to secure them from unauthorized access. To achieve that;
Open the .rar file-select file on the menu-click on the set default menu and create a password. Your .rar file will now be encrypted with a password. This will limit the access of the file to you only and the person you share the password with. Encrypting files will increase security and limits access.
If you have lots of files on your computer that you are not using but are important to you, one way of protecting them instead of encrypting every file is to compress them protected with a password. It’s just like encrypting them because the files are protected with a password and the good thing about this is that you also save space aside from encrypting them.
Download 7-Zip File Archiver and install it. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. Now, to compress your rarely used files, copy them to a folder then press CTRL + A to select all files. Once all files are selected, right-click on a file then point to “7-Zip” and select “Add to archive.”
On the next screen, make sure “Archive format” is set to “7z” for the best compression. In “Compression level,” set it to “Normal,” “Maximum,” or “Ultra” but not the lower settings. To encrypt your files, on the “Encryption” section, enter your password twice. You can also check “Encrypt file name” to also encrypt the names of the files. When you are finished, click “OK” to begin compressing the files.
When 7-Zip is finished, you will see the compressed file in 7-Zip format (*.7z). You may now delete the files and leave the 7z file on the folder.
Discover the ins and outs of Krikya Bangladesh, a prominent bookmaker in the online betting scene. This detailed review covers everything from the diversity of sports betting options and casino games to user experience, security measures, and customer support efficiency. Whether you're a seasoned bettor or new to the online gambling world,
find out how Krikya stands out in the competitive market of Bangladesh.
Construction management is essential to ensure project completion in a timely and cost-effective manner. Construction management software support businesses to operate efficiently. The software is available for all types of construction projects, including residential...
Mirrorless camera is the latest obsession among the photographers. The cameras have altogether replaced the traditional DSLR models with their unique and special features.
A mirrorless camera is a light-weighted electronic device device that utilizes...
1....
