How to speed up internet surfing and browsing
I heard from one of my friend that there is a program which can make our computer faster while browsing or surfing. But i cant find any software which helps me to solve my problem. Kindly if you have any information about  my problem then please give me a better solution.
My problem does not belong to internet connection i just want to speed up my system.
Best Answer by mamnoon ahmed
Answered By 0 points N/A #119154
Dear sibtain,
  • There is no any particular software which helps to improve the speed of your browser but only there are some techniques on the basis of which one can speed up their browsers and those are not very difficult ones but a simple and easiest. Some of those I am going to tell you here:
  • First of all you can scan your browser from viruses it helps to improve your browser speed.
  • Another way is that you can remove your history of the browser it again helps to improve the speed.
  • Deleting the temporary internet folder files from internet options also helps to boost up the speed of browsers.
  • Go to the start menu and the open run command and write there PING it will also helps it increase the browsing speed.
Answered By 0 points N/A #119156
Dear sibtain786,
Here are some important facts to be considered:
  1. There is a software named "speedconnect internet accelerator v.8.0" which can help you to increase your browsing , upload and download speed. you can download this from "www.cbs-soft.com".This software will be very much helpful for you.
  2. clear your all history by "cc cleaner " software . this will help to make your browser fast.
  3. you can use faster browsing software of new version to browse fast.
  4. If you are a explorer(4,5 or 6) user than  follow the followings:
  •  Click Start – Run.
  • Type "regedit" and click OK.
  • In the left pane navigate to HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionInternet Settings
  • In the right pane you should see the contents of Internet Settings.
  • Check Regedit's right-hand column for the following two lines (values): MaxConnectionsPerServer MaxConnectionsPer1_0Server
  • If these values are present, right-click on the first value (MaxConnectionsPerServer), select Modify from the drop-down menu, click Decimal, and set the Value data field to 6. Repeat this process for the second value (MaxConnectionsPer1_0Server).
  • If these lines (values) are not listed, right-click on the white region of Regedit's right-hand column, click New, and then click DWORD Value.
  • Enter MaxConnectionsPerServer for the name of the new DWORD Value and press Enter. The new value should now appear in Regedit's right-hand column.
  • Right-click the new value and click Modify.
  • As in step six, click Decimal and set the Value Data field to 6, then click OK.
  • Repeat steps seven through 10 using MaxConnectionsPer1_0Server as the new DWORD Value name instead of MaxConnectionsPerServer.
  • Close Regedit and test Internet explorer.
Answered By 590495 points N/A #317127
Yes, it is possible to go beyond the advertised speed of your internet plan but this is not free. You can do this with a VPN but there is no free VPN anywhere on the web. Though there are no free VPN services, the cheapest I found costs $1 a month but to get the $1 a month rate, you have to buy the 2-year subscription plan.
For more info, go to LimeVPN. Another way to speed up your connection is with TCP Optimizer. This tool is targeted towards broadband internet connection but you can also use it for other types of internet connection from dial-up to Gigabit+. The program doesn’t require installation. To use, just download and run it. In “General Settings” tab, move the slider to your internet connection’s advertised speed.
Select “Optimal” then click “Apply changes”. Follow the instructions then click to restart the computer. Another tool that you can use to speed up browsing the internet is DNS Jumper. It allows you to change your current DNS and use a much faster DNS servers.
