No of visitors who read this post: 291
Category: Internet
Type: Question
Author: Taashi
No votes yet
How to make the file to a minimum size ?
I have a file which is about 12.6MB but I need it to be lower than 3mb.
Is there any software or something?
Comment viewing options
Dear Taashi,
You can keep your  file size minimum. But I am little bit afraid to suggest you the way of keeping your file size minimum because you have not mentioned what is the file file format that you want to keep minimum size. There are some different method for reducing file size for different method.
And a file may be of different sizes when it is on different format.
However here is the some common things you can try: Here
You can optimize your image file from: Here
If you want to reduce your video file size then try: Here
It will not only allow you to reduce video size but also converting to any form.Links given here are free and no registration or purchase required.
# (Solution Accepted)
You may use software to minimize files.FILEminimizer Office compress PowerPoint presentations, Word documents and Excel spreadsheets without changing the file formats. FILEminimizer Office reduces the size of PowerPoint, Word & Excel files by up to 98% using an intelligent compression technique for graphics and embedded objects which preserves the original file format and quality.
The optimized files are then much smaller, safer and ideal for sharing and sending via e-mail. Recipients don't need the software to edit or view the optimized files. Mailboxes, servers and networks are relieved and loading time is accelerated. Why FILEminimizer Office is what you need: Reduce the size of all Microsoft Office files by up to 98%: a 50 MB file can be reduced to less than 1 MB.
Supports Microsoft Office 2007: Compress DOCX, XLSX and PPTX files. Keep the original file format. no unzipping required. Pack and Go: send optimized email attachments with one click. Search Wizard: find all PowerPoint presentations, Word documents and Excel spreadsheets on PCs and networks. Outlook & Lotus Notes Add-in: compress Excel, Word and PowerPoint attachments automatically before sending. Windows 7 compatibility FILEminimizer Office also exists as Server edition with a lot more features for companies and organizations willing to improve continuously their storage management.
To download the software please click the following link.
Read more: FileMinimizer Office - Download.com
