How to install panda home 2 on a boost mobile android phone?
How does one install panda home 2 on a boost mobile android phone? I just bought approximately a wall paper worth10$ but I cannot use because panda home 2 is not available on my android market and when I tried to get it through downloading, it never installed!
Answered By 0 points N/A #157490
If you do not have PC suite installed in your computer, then download and install it. You can find this at the Panda’s official website. After you have downloaded and installed the PC suite in your computer, connect your android device using your USB cable. A notification will prompt you to install PandaDaemon, this will enable the PC Suite to recognize your phone after installation. You can now install the APK file of Panda Home Installer and install it on your android mobile.
