How to install edimax USB wlan driver effectively?
Dear Techyv members, I hope all is well. I would like to know how to install Edimax USB wlan driver effectively. What are the steps needed for this kind of driver? Do you think this is any good? Please include your own review and its overview as well as its key features.
Answered By 0 points N/A #136964
Hi Ruthtmagnuson!
You need to specify the model of the Edimax Wireless LAN Adapter that you are using for you to be able to install the correct driver. You can do a product search at http://www.edimax.com/edimax/global/
Once you have found the product, click on it and scroll down to get the features and specifications as well as the necessary driver. You can also download the quick installation guide and the user manual for the Edimax Product. According to customers' review, they find this product handy and so easy to use when it comes to its interface. Performance-based, this product is also well known to be able to solve internal WLAN Card issues. This product is a very effective and easy alternative for bad WLAN cards.
