How to insert ascii page break?
Aspen is uses the ascii page break to split simplates and hook in very pages breaks to character this what is ascii. My question is How to insert page breaks in ascii text file? Please help me.
Thank you so much.
Best Answer by Sharon D Mickelson
Answered By 30 points N/A #147300
To insert page breaks in Notepad++, all you have to do is go to edit>>character panel. You will see a list of ASCII characters to the right.Choose the 12th one which is FF, stands for Form Field.This is for page breaks.
Hope this helps.
Answered By 10 points N/A #147301
Hello Elias,
A page break creates a form feed that is sent to the printer.
The form feed character code is denoted by 12 (0xC in hexadecimal).
The shortcut key to insert a page break in ASCII text file is
Press CTRL-P and ALT+012 on your keyboard.
Hope this will be helpful for you.
