How to image resize on mouse over ?
I need to resize some picture from higher dimension to lower dimension without changing the quality of picture. How I can do image resize on mouse over and which software is effective for this purposes? Need help ASAP.
Best Answer by Oswald Nicola
Answered By 0 points N/A #168317
There is a lot of software to resize the image of your mouse over, but I recommend Perfectresize 7.5 Onone software.
Answered By 0 points N/A #168318
Hello Snider,
You can resize pictures from higher dimensions to lower dimension without changing the quality of pictures. There are many software of resizing images, you can download a good one from below link.
http://www.stoik.com/products/photo/STOIK-Smart-Resizer/
It is also possible to resize a picture without using any software. You can also resize images on online. Visit this link to resize on online:
http://resizeyourimage.com/index.pl
