How I can recover data from locked hard drive?
Hello guys,
I have a password locked HDD and need these valuable data recover. Can you tell me how I can get my all these valuable data from locked HDD. Is there any recover data from locked hard drive software? If you know how to do it please help me with details. If you can describe step-by-step process it will be fantastic.
Best Answer by Travis J Grigsby
Answered By 50 points N/A #142805
You've to go for hard drive data recovery services to get back data from password protected hard drives.
You can read the tutorial posted here for further clarification.
Answered By 40 points N/A #142806
Your problem occurred may because of two reasons. Firstly, there may be a hardware bug, or someone might locked the drive in the BIOS. I would suggest not go for any software tool as using of such tools are quite risky. Its better to consult with any of professional service Centre. Or you may contact with your computer manufacturer for further assistance.
Please visit the link for your reference https://superuser.com/questions/355452/recover-a-locked-hard-disk
Thanking You,
Margaret M Griggs
Answered By 30 points N/A #142807
Check out the EaseUS Data Recovery Wizard software.
The download instructions are as following:
1. Click on download link to get Data Recovery Wizard
2. Do not save and install on a drive where your files were lost. Save in some other drive.
3. Run Data Recovery Wizard software, search your drive and browse the files found in resulting screen.
There is another thing called AFF repair station. Have a look, it might be useful.
Following link also will be helpful for Unlocking a password protected hard disk:
https://www.rockbox.org/lock.html
Thanks..
