How I can make free website
I would like to make free web site that will be used with personal information but I do not know how it can be possible.
I expect to get genuine details information from the experienced person so that I can make it personally.
Best Answer by Henry corn
Answered By 0 points N/A #125753
You can make free website for your own wish. There are many websites for support you. You can also have free hosting and might have free template as well. It is very simple. Just go to one of those websites that have this type of opportunity and then register with your valid email address and then log in with username or email and password. Then if you know how to use template then do the rest. Or if you can do HTML coding then do it. You will get some free space for hosting. I recommend these websites for hosting.
1.       http://www.webs.com/
2.       https://www.wix.com/
3.       https://www.ucoz.com/
Answered By 0 points N/A #125754
Hey hi, Its very easy to make your own free website.
Just follow the simple instructions and at the end of the day you'll have your own free website.
1) Go to this web site http://www.webs.com/
2) Once open click on "Start Now".
3) Now you got to create your account there. Fill up a simple form and that'll create your account.
4) Select the theme of your web page.
5) Agree terms and conditions and click on Create My Website.
6) When completed to got to select your site type from the list.
7) Now you got all the tools and options in there just add all the information you want to add.Make your home page, add pictures or what ever you want to add to you site it will guide you step by step.
8) Follow all the steps and you'll end up making your free website
Hope this will help you.
Regards
Colbert
