How to ground dynamic ambient lighting to PC’s power supply
I’m trying to connect the ground to the PC’s power supply. I can’t seem to find where to put it. Should it be on the chip somewhere that I have to connect to? Can anyone give any idea on how to do this?
Answered By 0 points N/A #188677
Hello Paul
PC's power suppler come with an entry point that have 3 metal sticks coming out of in on a shape of a triangle (you cannot miss it) right and left top ones are the positive and negative power lines, as for the one in the lower middle is the ground.
But if you are asking about where is the Ground line inside the PC then look for cables coming out from the other board with a small writing next to them "GRD" they normally come in black color you can't miss it.
I strongly Advise you to take your PC to a professional so you want by mistake short circle your PC.
