How to get rid of Y-socks port scanner error message?
My PC is showing "This application failed to start because Y-Socks Port Scanner By _-Rs-_.exe was not found. Re-installing the application may fix this problem." Please kindly give me the solution for this problem.
Thanks in advance.
Answered By 0 points N/A #163919
Hello Louise,
It seems you have a big problem it might cause by different problem here is the list,
  • Trojan affecting your PC
  • Conflict with other program
  • Damaged or ivalid EXE
  • Corrupt registry
  • Removed files by accident
First if you have any anti-virus please scan your PC and look if there is just a virus affecting your pc.
Secondly please have a CHECK DISK.
And last please try to Clean your registry by using a particular program like Ccleaner or Clean My PC Registry.
It should fix your problem by no time and remove the un necessary dll., exe, files or programs. I hope I helped you out with your problem if you have another question please be free to post it here thank you.
