How to get free aol art viewer download?
How to get free AOL art viewer download? I just want to get an art viewer application but unfortunately I got an error before and it says about compatibility error when I was using my windows 7 64 bit operating system I am wondering what is wrong? I hope you can explain it to me for us to resolve the problem.
Thank you.
Best Answer by Downer halt
Answered By 5 points N/A #182763
Hello Shannon,
You can use Irfanview which is a free software that can be used to view various media files. I hope you can view your aol .art files also.Just give a try. The download link is mentioned below:
Answered By 0 points N/A #182764
Good day Shannon,
Before having an AOL art viewer, check first your hard disk free space. If it has a bigger space then you can download the AOL art viewer but if it has no enough space, then omit some file to have a bigger space.
Best thing to do is to download the latest version of AOL Desktop because it’s already a complete software setup where every AOL software products is available and ready to download and update anytime. And that AOL desktop is compatible with windows 7.
Hope this can help you.
