How to fix Microsoft Office 2010 Error 1935
Hello experts
Typically the following message appears when I try to setup Microsoft Office 2007 or Microsoft Office 2010.
The error message shows when the process does not finish successfully.
The error message is:
Error 1935. An error occurred during the installation of assembly
‘Microsoft. MSXML2R ,processorArchitecture=’’x86’’,publicKeyT ok
en=”6bd6b9abf34538f”,version=”4. 1. 0.0”,type=”win32’”.
Please refer to help and Support for more information.
I need to remove this error. Please help.
Thanks a lot.
Answered By 0 points N/A #140988
First remedy is to restart your computer and try if it works this time.
 If it still does not work, you have to repair your Microsoft .NET Framework.
To do that, go to your Control Panel. Look for Microsoft .NET Framework 4 Client Profile.
Click it and option to repair will show.
When it's done, restart your PC and check if will work fine this time.
