Alice Macek
60 points
Posted on - 04/25/2013
Hi Techyv!
I need help with my ESET NOD32 antivirus. When I’m about to update my antivirus, it’s asking for a username and password which I’m not sure where to get from. I didn't sign up for anything and don’t know why it’s asking for a username and password. If anyone had experienced the same problem, please help me. Also, If anyone knows how to fix the other issues such as performance and slow browsing issues for ESET NOD32 all versions, then please share your expertise. We will be very happy to follow your advice. Thank you.
How to Fix the ESET NOD32 All Versions Issues?
HI,
I am assuming that the version of the antivirus you are using is genuine and that you have the casing in which you bought it in.
The first time you install your eset product, use your Activation Key:
1.   You art to find the activation key that should be printed inside your product package.
2.   just after you have installed it, you are to choose the "activate using an activation Key" in the window displayed.
3.   finally you are to use the key provided to you from your package to complete the activation.
If you purchased at eset.com,you should have already received a username and password by email that must be entered into your product either during or after installation.
If you forgot or lost your Username and Password, visit the Lost License page.
