How To Fix “advrcntr4.dll Is Missing” Nero Error
I have just installed Nero 9 then suddenly an error appears on my desktop. I am getting upset about how to fix this because i have still a lot of projects to do. I have searched a lot of posts on this subject but have not found any useful information.
Hope Anyone of you here can help me solve this problem.
Nero Control Center
Error Starting Nero Control Center
Can't load Advrcntr4.dll
Nero Control Center Error Starting Nero Control Center Can't load Advrcntr4.dll
Best Answer by Ssoumyadiproy
Answered By 0 points N/A #122323
Scanning your PC using Reginout System Utilities will repair the dll error.
Answered By 10 points N/A #122324
Hello Madelduenas,
There may occur several errors associated with"AdvrCntr4.dll"file. Sometime we get errors like "'AdvrCntr4.dll'file missing". Now as Nero is a market leader as CD/DVD burning software so we need to have some quick & easy solution of this problem.
There are several ways to fix the problem——
1st way:
This is the most simple & easy way to fix the problem, just re-install the Nero software. That will install all the files fresh & your problem will be solved, but it is sometimes less time consuming.
2nd way:
Here is another way to fix this problem, it is a manual way to replace the .dllfile. Try to download the"AdvrCntr4.dll"file from Nero server. Then go to system32 folder & locate the current "AdvrCntr4.dll" file.
Rename the file as"BackupAdvrCntr4.dll"& copy paste the new file. Then go toRun->cmd->type "regsvr32advrcntr4.dll" & press enter.
Now you are done by solving your issue.
3rd way:
There is another way that may cause this issue , that is your registry database. If this registry database is the cause then try any registry cleaner & repair software to fix this issue.
I am hoping that I am able to solve your issue.
Thank you.
Answered By 20 points N/A #122325
This Nero Error "Can't load Advrcntr4.dll" occurred because of the deal file was deleted from your computer.
Please see the details below:
1. The dll file from Nero folder was accidentally deleted by the end-user.
2. The dll file from Nero folder was deleted or removed by antivirus because it was considered as a threat issue.
3. The dll file from Nero folder was accidentally moved by the end-user.
4. After Nero software update.
5. Re-installation of the Nero program.
In order to resolve the problem, you must first take note of your Nero serial number and uninstall the Nero program.
Restart your computer after un-installation and Install a fresh copy of the Nero program on your computer.
Hope this will help to resolve your problem.
Thank you,
Lhana
