How to faulty ram repair for Intel based PC
Hello Experts,
I am using two 1 GB DDR2 RAM on my Intel based Windows XP Desktop computer. Recently one of the RAM has become faulty and I am left with single 1 GB ram to operate my Desktop. I want to know if there is a way to faulty ram repair.
Answered By 30 points N/A #171449
Hello Gipe Mungo,
The Rams can be repaired only if the problem is not so complicated.
Means if you see that there is a damage on RAM then you can repair it only by replacing the damaged chip of RAM.
But if you think that your RAM's circuit board is damaged, then there is no chance to get the RAM repaired.
Please remove your RAM and clean its edges.
I hope it will run properly.
