How to embed videos from to youtube to blog
I have a blog and I also have some videos uploaded from youtube. Im not good with this stuff so I need help. How can I embed videos from youtube to my blog. Is this possible? I want to use it to attract viewers to my blog
It is quite easy to embed a video from you tube. Just follow these simple steps and you are done with it.
It will take maximum of five minutes in all this process and I hope you find this information helpful. Hope your problem is solved.
Hi Jennifer,
So you want to get some videos from youtube and embed them to your blog. It is easy. You will need to get youtube downloader.
Copy the url of the video that you want to download in the empty download field in the downloader and click download. Be sure to choose the format you want the video to be in. e.g avi, MPEG and so forth. Do that for all the videos that you want to download.
Thereaefter, go to your blog. I believe there should a place that lets you upload upload videos. Go to it, choose the location of the videos and upload them to your blog.
Hope this helps you. Enjoy.
Regards
-alphae-
