How to draw a hard disk pie chart?
Hi everyone,
How to draw a hard disk pie chart? I have to make some report about hard disk pie chart using Microsoft PowerPoint application. Can you give me some ways to get a video or online tutorial? I really need some help.
Thank you and have a nice day.
Best Answer by Lawren chavez
Answered By 0 points N/A #178440
It's very simple to have a hard disk pie chart.You can download hard disk pie chart from the link and make a power point presentation of your need.
Moreover,you can watch the you tube video below.
You can also see the link for further action and more knowledge.
Answered By 0 points N/A #178441
You can use Microsoft Excel 2007 for this purpose. All you have to do is to export your data in CSV or excel workbook format. Then follow the following steps to make a pie graph,
1) Open your exported data in Excel.
2) Select the data required for Pie chart.
3) Go to the INSERT menu and click on CHART.
4) In the Chart Type box, choose PIE.
5) For quick view, click ‘’press and hold to view sample’’.
6) Click next and save your PIE chart.
Answered By 0 points N/A #178442
Hi Greqory Gregory,
It is very easy to create a pie chart in power point. Follow these steps:
Insert new slide
In Click to add title, type your chart title
In Click to add text, select insert chart
In Insert chart pop-up window, choose pie in the left pane and choose kind of pie in the right pane > OK > appears Microsoft excel program > create value for your chart. You can see your chart change when you create value. Close excel when you finish
Hope this helps
