No of visitors who read this post: 479
Category: Internet
Type: Question
Author: Arlet Joson
No votes yet
Has anyone encountered video downloading problems like I do? Whenever I download videos in video sharing sites like YouTube, Vimeo, Dailymotion or the like, it would start its normal download but stops playing after a few moments though the download still continues. I tried doing it in other videos thinking that maybe the video itself is the problem yet I still got the same result. Could somebody please help me with this?
Comment viewing options
Hi Arlet,
Can you advise what application you use to download? There are some instances that if you download files from Vimeo or Mega video, there is a limit of minutes you can watch. You have to wait for their buffer to clear before you can continue to download.
You can try to download and install ant.com plugin. You can install it on your browser and it will download the video file for you. There are also other plugin that can do the same thing. You just need to look which one best fits your needs. Try to also download from site that does not have a limit of time for the download.
Aristono
# (Solution Accepted)
Which programs are using to download the videos from those sites? There might be several reasons for that occurence, and I suspect that it is due to the following:
  • You internet connection status is not stable. The internet is ON and OFF and that is why the download starts and then stops and continues. So you will need to troubleshoot issues that may be leading to unstable internet connection on the network that you are on.
  • I will also suggest that you try the following video down loaders that I have used and found them to be impressive. YouTube down loader for downloading videos from YouTube, Internet Download Manager and the Orbit down loader. All these can be downloaded for free from the internet.
Lee Seen
