How to download this Mac vst player
I am using a mac operating system and i want to download a vst player for my computer. What is the step by step method to download and install it in a safe way.
Thank you experts.
Thank you experts.
I see that you want to download a vst player for your mac. Apple has launched an audio plugin through which you can play vst files. You just have to install the plugin and then you will be able to play vst files. Follow the steps below:
1. Go to https://www.macupdate.com/app/mac/41579/audio-plugin-player and download the plugin. You can even get it from the App store.
2. Save the plugin setup on your computer and then run it from the desktop.
3. Follow the instructions in the installer and choose apply plugin to all players.
4. After the plugin is installed you will be able to play vst files.
Hope this information helps you.
