How download Email redirector for android
     I am using Black Bery Cell phone I want to download Email redectior for android application but it does not work in my cell phone .Can any  one please tell me how i download Email redirector in my cell phone ?Is there any specific way to download the Email redirector for android ?
Best Answer by lee hung
Answered By 0 points N/A #193581
Hello armstrong,
Simply download and install Launch TcForward ,add the email address or mobile number you wish to forward to and Try to configure the folder redirection to receive an email in your black berry mobile phone, or enabled from the emailed setting tools.  And you phone is ready .Maybe it does not work because you did not enabled your email setting tools.
I hope that helps you. 🙂
Answered By 75 points N/A #193582
Armstrong,
Thank you for your inquiry.  To load the Blackberry email redirect you just need to do a few small things.  First,  you need to make sure you have the latest Desktop Manager installed.  To check on your Desktop Manger you can look at the installation disks that came with your device or go to the support section of your providers website.  Once the latest version is installed on your device, in the Blackberry Desktop Manager window you should see the 'Redirector Settings".  Click on this option and it will walk you through what you need to do in order to set things up for redirection.  The main step you will go through is entering the name of the email account you want configured, your device will try and setup a secure key that will be used to encrypt  all data sent to your Blackberry.  Once this setup is complete you will need to restart the Desktop Manager so any changes you made will take effect.  Your email redirector is now setup and ready to go.
