How does an AutoCAD Drawing Convert to PDF file?
Hello Experts!
 need expert’s advice on how does an AutoCAD Drawing Convert to PDF file. Do I need to use third party software or there is an available tool or utility which converts drawing files to PDF files? If you have used this before or is currently using it, please share it with us and tell us how is your experience upon using the application. Have you faced any problems? Any sharing from anyone will be much appreciated.
Thanks much!
Best Answer by Duncan Courtright
Answered By 0 points N/A #132926
Download and install a free pdf printer such as dopdf. Go to their homepage and http://www.dopdf.com/ and find the download link. Install it then 1 On the autoCAD main window click File. Locate the file you want to convert and open it. 2 Select print. 3 Choose the installed pdf printer. 4 Choose where you'll save the file and click OK. 5 Do pdf will generate the pdf for you. OR if commercial software is your sort of thing: You'll need to find the right software to convert .DWG files to pdf. Any DWG to PDF Converter is one such program which you can use to convert your autoCAD drawings into pdf. Like most commercial software Any DWG to PDF Converter offers a free trial version which you can use upto 30 times to let you decide if it's worth the selling price $83. It's always advisable to try out the product before you buy it so if there are issues you can sort them out with their customer care department and if you're convinced you'll be getting a great deal go ahead make the purchase. Use this link to download the free trial of Any DWG to PDF Converter http://anydwg.com/download/dwgpdf.exe
Answered By 0 points N/A #132927
One of the best AutoCAD to PDF files converters is "Any DWG to PDF Converter" it's simple and pretty straight forward to use and the result is satisfying.
The only issue that i found with it is the 30 day trial period so if you want to work offline you'll need to buy the software.
There's an alternative which is a website called "Zamzar" that converts different file types including DWG to PDF online for free without any additional software.
Answered By 0 points N/A #132928
Hello Collins,
I understand your problem and I will provide you with an easy yet practical solution that will help you. I think this converter application  is suitable for you and you only need to add the required file to convert then click "convert now ".
You can install this application using this link:  http://anydwg.com/dwg2pdf/
Cross Bohon
