Hello! I have configured Microsoft Outlook 2010 on my computer to use in sending, receiving mails and relaying alerts. The settings are such that the junk mail of off. Can someone send me a procedure on how to turn on junk mail? Kindly make it as simple as possible since I am new in using Microsoft Outlook. Thanks big time, I appreciate.
How do you turn on junk mail?
Hello! Your Microsoft Outlook Junk Mail is not turned off but may simply be at ‘High’, which means the Outlook will block any junk mail that it can detect and not let it get to your Junk Mailbox. To change this, under Tools, click Options. Look for the Preferences tab under Email. There you will see Junk E-mail, click it. You will be provided with the level of protection of junk e-mail where you can change. No Protection means it will allow all spam/junk to be placed in your Junk Mailbox while changing the level higher tightens the protection.
Follow these simple steps to get your junk email working for you.
* Open your ms outlook 2010. Go to home option and click on the junk.
* Now in junk click Junk mail options. You will see this window is open for you.
* Now See these simple settings. Just copycat do nothing else. Everything will start working fine.
