How do I create VPN for adsl connection?
Hi guys.  I'm quite new to VPN.  I have a ProSafe 802.11G wireless ADSL modem VPN firewall router.  I would like to create a tunnel in VPN for ADSL connection to have a secured data transmission.  How do I create a tunnel?  I'm on  Windows OS 8.  Thanks.
Answered By 5 points N/A #173376
You did not specify the exact model of your ProSafe Wireless Firewall Router so we can provide the exact configuration that you need. Anyway, try visiting the PDF file from the link below:
http://www.downloads.netgear.com/files/GDC/FVS318N/QSGVPN_4Apr2012.pdf
It contains all the information that might help you configure your VPN Tunnels. Or you can also try the workaround given below:
First of all, in order to set up a VPN TUnnel, you need to ensure that the entire settings and parameters on either sides of the tunnel will match or mirror each other correctly. And this is not an easy task. To create a VPN Tunnel, navigate to the link below which provides the manual for Netgear ProSafe VPN Firewall. Go to page 96 to learn more about how you can create a tunnel.
https://www.manualslib.com/manual/358648/Netgear-Fvs338-Prosafe-Vpn-Firewall-50-Router.html?page=98
