How do I completely delete Spb wallet firefox extension?
Hello.  I'm using Mozilla Firefox Version 18.0.2 and I recently noticed an SPB Wallet add-on on my toolbar. I uninstalled the add-on but there are still traces of its code.  How do I completely delete SPB Wallet Firefox extension?  Any suggestions would be a big help.  Thank you.
Answered By 90 points N/A #171599
Hi there John S Michaud
This is a simple problem, this happen because when you uninstall an add-on its extension remains with the browser so you need to remove it manually to delete it fully. Follow these steps
Step 1 – Open Firefox
Step 2 – After opening press ALT button on the keyboard (It will show a menu bar on top left side)
Step 3 – Go to Tools on the menu bar
Step 4 – Click Add-on (this will take you to Add – On manager)
Step 5 – Select the add – on you need to delete and delete it
Best of Luck
Taylor B Campos
Thank You..!!
Answered By 590495 points N/A #303218
I don’t think there are special instructions when deleting extensions in Mozilla Firefox. You just delete it from the extensions section and the extension is uninstalled. In Mozilla Firefox, go to “Tools” then “Add-ons” or press CTRL + SHIFT + A to access the Add-ons Manager. On the “Add-ons Manager” tab, select “Extensions” on the left pane then look for the add-on you want to uninstall on the right.
Click “Remove” to uninstall it. If you want to make sure the extension is removed completely, press CTRL + SHIFT + DEL then clear your browsing history. Set the range to “Everything” then select the options you wish to clear. If you still doubt that the extension left some files, go to CCleaner Free Download and download the free version.
Once installed, run CCleaner then clean your system and then restart the computer. If you want to convert CCleaner to Pro, download the codes and follow the instructions.
