winnie zac
90 points
Posted on - 02/08/2013
I use BS. Player 2.64 and I use it for watching MicroDVD. sub videos which can also search and download subtitles.Â
I'm having a problem with 1 video file with no subtitle showing in BS.Player but shows up in VLC.Â
It seems BS.
PLayer does not recognize the subtitle.Â
How do I add or delete caption with subtitles bsplayer 2.64?
How do I add caption with subtitles bsplayer
Hello Winnie,
Thanks for choosing us.
About your concern, BS Player does not support DVD closed captioning (DVD CC) thus it only supports DVD subtitles.
Here’s the official forum of BS Player: in which it is related to your concern.
Please let me know if I can provide any further assistance.
Have a good day!
Hobbes
Hello Winnie,
The problem you mention it may occur if the embedded subtitle is enabled so at first check that.
You need to disable it to go through the Options first then Preference and at last Subtitle.
You can try BS Player pro version also which can display two different types of external subtitles in two different languages at the same time.
Hope this help you to resolve the matter you are facing.
Thank you.
