No of visitors who read this post: 187
Category: File Servers
Type: Question
Author: Dallas Corey
No votes yet
I have been trying to constitute the is_config.xml file to talk to an OID server for retrieving user and group info, then I getting a error message the “ORABPEL-10519 error ( Service cannot resolve identity in realm "{0}" )”.
I am trying different variations but cannot solve it to work.
Regards
Dallas Corey
Comment viewing options
I think you need to read and understand the program’s proper documentation including its manual if it is available for the proper procedure on how to do the task that you are trying to execute. But when I saw the name of the XML file that you are trying to access and maybe you already edited some of its lines, I’m not sure if you are doing it the right way.
An XML file usually contains the right sequence of the programs that needs to be launched or opened. I’ve already checked one of these when I am having a hard time upgrading my Windows Media Player 9 to Windows Media Player 11 because the upgrade requires an original version of Windows and I am using a cracked version of Windows which really makes the installation not possible.
But after doing some web searching and also after examining the contents of the XML file [I extracted the contents of the Windows Media Player 11 setup file, I learned the correct sequence of the installation and just applied it and skipping some files that are not needed.
Normally, XML files are only parsed by the application.
Regards
Sharath Reddy
