How to crossfire ATI Radeon HD 5750?
What is graphics card crossfire and what are the advantages? I have two ATI Radeon HD 5750 graphics card. Can i crossfire between these two cards? If then, how to do it and do i need anything else to make this crossfire?
Best Answer by Meyers Marchan
Answered By 10 points N/A #125745
If you want to have a croosfire graphic card, you need to have an item for High end.
The example of this is GIGABYTE G1 Killer.
and this one is the crossfire.
You need to have the 4 0r 3 video card slots in your motherboard and this can be found only in HI  END.
You cannot insert any crossfire graphic cards in an ordinary Motherboard with 1 graphic card slot.
Hope this will help.
Answered By 5 points N/A #125747
The advantage having a double graphics card is to make it more realistic in games and high definition movies the 2 or more slots are called SLI yes you can upgrade more graphics card make it more powerful in games  ATI Radeon are the best so far in terms in graphic cards just you make sure compatibility.
Answered By 5 points N/A #125746
