How to create software bridge w7 starter ?
How to share(bridge) net connection between a Netbook which powered by Windows 7 Starter and a desktop computer which powered by Windows XP service pack 2 64 bit version? ( Windows 7 starter does not support the network bridge).
How to solve this problem? Is there any 3 rd party software as a solution?
Best Answer by Claraj jane
Answered By 10 points N/A #162389
First of fall You will need a CCproxy software. Here is the URL to download
Its will became very simple and easy to make bridge connection between both of your system but make it through your netbook which is powered by windows 7.
First of fall go to control panel where you will see network and sharing Centre. Click on it. It will open and you will see the option change adapter setting. Click on it and it will open a window. Right click on connection it will open options there will be a bridge connection option click on it.
Hope it will resolve your problem
Answered By 0 points N/A #162390
Thanks for sharing your problem. Bridging networks is easy and is supported by windows. First of all make sure that you have connected your desktop and the netbook via a LAN cable. Then follow the steps below:
1) Click "Start"
2) Go to "Control Panel"
3) Network an sharing center
4) Manage Network Connections
5) Highlight the network that you want to bridge
6) Right click on one of them
7) On the drop down menu select Bridge Connections. DONE!
