How to create html5 vertical navigation?
Hello guys I am new at Web design and I am creating a Personal Website.
I am facing trouble.
I need to create HTML5 vertical navigation, but I can not.
Can you tell me how I can do this. If you can provide code it will be helpful.
Answered By 35 points N/A #187732
Hi, To create vertical navigation you not only need HTML5 but also CSS. The HTML code is given below
You have to use CSS to make it look vertical. I will be using CSS3 here-
1) CSS for nav
nav{
display: -webkit-box;
-webkit-box-orient:
vertical; }
2) CSS for links
nav a{
display:block;
padding:10px;
-webkit-box-flex:1;
text-align:center;}
Hope this helps. For more tutorials check out this link.
