How to create file transfer multi threaded?
How to create file transfer multi threaded? What is the software or application that is the best for this kind of issue? And of course for security reasons I need a secure and free download of a software. Thank you experts.
Best Answer by Franks good
Answered By 15 points N/A #149829
You want to know about file transfer multi thread creation. You may find this task a bit difficult. But with the help of some very good soft, you can do this easily. You tried to have some help on free downloading these software. May these links help you:
Answered By 15 points N/A #149830
The best tool for multi threading is RichCopy tool.
But you should know that it not work as you think. All it do is manage to open multiple files/threads simultaneously which is done by parallel processing. But one good advantage is if you performing copy operation and you lose your connectivity then you can pause it and later any time it get connected it will pick up from where you left it off.
Here is the secure link. You can download it.
Just click on it and it will let you download directly
