How to create DVD from divx files
Asked By 7060 points N/A Posted on -
Hi!
I have many movies in my hard drive.  i want to watch them on my DVD player instead of my computer.
I tried direct copy of the files to DVD but my DVD player doesn't seem to support AVI or DIVX file playback.
Is there a software that can create a DVD for playing on any standalone DVD player?
Many thanks!
Best Answer by Ray_Palmer
Answered By 0 points N/A #79680
I can recommend two freeware applications that can do what you want.
1.  DVDflick – it is one of the most popular applications for authoring DVDs.  It can convert almost any movie format into DVD including avi, mpg, and mkv.  It can also create professional-looking menus to make it look like a real DVD.
2.  AVStoDVD – is another popular application.  Most enthusiasts prefer this over DVDflick due to it's more powerful set of features.  AVStoDVD is actually a combination of several other software that encodes, multiplexes, creates DVD-style menus.
Currently, AVStoDVD is what more movie enthusiasts prefer due to recent problems with DVDflick having audio out of sync with the video.  DVDflick is, however, much more user-friendly especially to first time users.
Answered By 0 points N/A #79681
For your problem with burning DIVX movies to a playable DVD format is just downloading and installing conversion software. There are a number of software out there for you to use but the software I would recommend for the job is VSO ConvertXtoDVD.
This will make the burning of your DVD movies very easy and fun. The software converts every format of video into an ISO image playable with any DVD player. That’s not all download the software automatically burns the image unto your DVD Disc as soon as the conversion is complete.
Just Get this software, install on your machine, and after the installation is complete, open it, drag your movies into the software, and start conversion.
Answered By 10 points N/A #79683
To create a DVD from avi file, you will need to properly format and convert  the avi file. Firstly you should download DVD conversion & creation application to use. There are two option:
(1) Roxio toast titanium
(2) wondershare DVD creator.
Next you should open DVD authoring suite & you should choose to start new DVD project. Now add avi file to your DVD project & choose DVD theme. You should see your application help for more information. Now insert your DVD into computer & add video files.
You can convert avi to DVD by downloading avi to DVD converter for macs. You can see a download link then you need to add avi files in a software by clicking “add video” button. You can add other format videos. Now you can add avi files if you want to convert into DVD by selecting DVD type. It is important to create DVD menu. Choose template & you can edit this by clicking on “edit” button. Now you are ready for converting. Yes there is a software, you can go to the links below:
https://videoconverter.wondershare.com/convert-avi/convert-avi-to-dvd.html
www.ehow.com/how_5754388_convert-file-play-dvd-player.html
