kevin rith
20 points
Posted on - 06/17/2012
I need to create 3 digital time piece showing three different time zones on my desktop. And show the time 12 hourly at am/ pm. I want to do this in Java. How can I do this? Please experts give an easy to follow solution.
How to create digital timepiece in java?
Hi Kevin,
I do find a very interesting topic while reading your concern regarding with digital timepiece. I think it is a bit complicated with the image that your up to but I think this codes will help you in making that code.
Kindly click this Links and check the code:
Digital Timepiece in Java
Digital Watch in Java Tutorial
It may help you in making your personalized digital timepiece.
Hope it helps you a lot with your problem.
Thanks and more power
