How to create a bootable USB drive
I would like to know how to create a bootable USB drive. Would it be difficult like in Windows XP? Does Windows 7 have the same process with Windows Vista wherein I can copy the files? The bootable USB stick that I had created only worked for x86. I have Windows 7 x64 right now.
Looking for help.
Best Answer by Emil Onoon
Answered By 0 points N/A #197533
Hi
I will certainly help you to create a bootable Windows 7 USB drive. Its became very easy to make USB, when Microsoft released  Windows 7 USB DVD Tool.
  • Download it from Microsoft website first and install it.
  • Then insert your Windows 7 DVD in your optical drive.
  • Browse the DVD from the USB Tool.
  • You will be asked to choose between USB or DVD.
  • Choose USB drive and insert if you have not yet.
  • Select USB. It will format it and will do the rest.
  • Your USB drive is ready.
Microsoft store
Answered By 5 points N/A #146955
I'm just want to share to you on how to create a bootable USB drive. First, go to link http://wintoflash.com/download/en/  then click and download the latest WinToFlash installer.
After you downloaded the file, please watch the video tutorial on this site link http://wintoflash.com/home/en/
I hope this can help you. Thank you.
