How to Correct S.M.A.R.T. failure in Hard Drive Error…
The hard disk with SMART may prompt an error at each startup, like:
I need a solution for this….
SMART Failure Predicted on Hard Disk 0: FUJITSU MHT2000AT – (PM)
WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imitent.
Press F1 to Continue
Best Answer by Sharath Reddy
Answered By 590495 points N/A #169581
The SMART (Self-Monitoring, Analysis and Reporting Technology) warning that appears in the BIOS when you are booting your computer is just to warn you of an imminent hardware failure on the part of the hard drive. But this does not mean that your hard drive is already broken. This is just to inform you that any time you might experience a hard drive error or a hard drive failure and it is advised that you do frequent back-ups on all of your files.
SMART enabled hard drives have the ability to internally monitor their own physical health and performance. Most SMART hard drives allow users to perform self-test on the disk and to monitor a number of performance and reliability attributes. You cannot fix a failing hard drive but what you can do is to prevent the failing clusters of the hard drive from being occupied by any file. You need to do a disk check using any disk utility program. Scan the hard drive for bad sectors. If the tool detected a bad sector on the hard drive it will be marked as bad block and prevents any program from writing to this sector of the hard drive.
If a hard drive starts having bad sectors or bad clusters these are signs that it will eventually wear out soon.  So you need to have a replacement before it totally goes down.
Answered By 0 points N/A #169582
The user ought not ignore this error message. Or even taken care of, the failure is inevitable and after that comes the requirement for Hard disk drive Recovery solutions. If looked after, such hard disks give lots of time to backup data. The difficult drive must be replaced and when user has valid and recent backup, it can be restored with no cost.
If one ignores this SMART warning, it may cost with regards to data loss and in this case hard drive recovery solutions could be the ultimate solution. At recovery services the pros first analyze the failed hard disk drives after which consider the necessary steps in order to retrieve the information as a result. Next the providers communicate the results with the customers who can concur their norms and scenarios.
