How to convert vob to m2v Mac?
Hello Experts,
How to convert vob to m2v mac? My mac operating is doing well and I am kind a comfortable with this kind of operating system but I just want to ask if it allows any download from the internet such as converters, for I need to get one application to get vob to m2v files be converted as soon as possible.
Thank you.
Best Answer by Cristina McCormick
Answered By 5 points N/A #186999
You can convert vob to m2v by using Smart Ripper. You can download Smart Ripper from HERE. Click on download link as per given image below.
Click on “Saves Files” to save it to your PC. The click newly created icon Softonic_Downloader_for_smartripper.exe to launch setup. After successful installation will be able to convert your files.
Answered By 0 points N/A #187000
Hello
I found good application and solution for your problem. Application is called Squared 5. It's all to all converter so you can convert all video formats to all video formats with this application. You can find it on this link: http://www.squared5.com/svideo/mpeg-streamclip-mac.html
It's easy to use and fully featured so you should try it.
I hope I helped you.
