Hi all experts,
I am designing my college website through html coding, I have to link some images, files and videos. I have one pdf file that contains maximum coding of that site, so I just want to convert that pdf to html file so that I don't have to do more coding part. Can any one help me in converting a pdf to html file.
How to convert PDF to html file format.
Hi Toby,
There are many ways to convert a PDF to HTML format, you can at first check the solution in the official website of Acrobat, it exists also some software you can use them to convert the all PDF file to HTML which are 'intrapdf" and "verypdf" and there is a different ways to convert images in the PDF files to HTML by these software, the best one is "ABLE2Extract Professional " but you have to buy it. Finally, you can use a website to convert the file and this is the link : http://www.pdfonline.com/convert-pdf-to-html/#
Douglas
